shell and linear variation of thickness
  • Thread starter Thread starter Dmaz
Dmaz
Hi, everyone is probably a stupid question, but I miss it. .
I have to create shell91 square elements with variable thickness, for example from 1mm to 2mm.
I can specify the thickness of each node tk(i), tk(j), tk(k), tk(l). my doubt is: what is the knot i, the knot j etc? or how do you order ansys knots? growing? If an element is formed by the knots 12 14 25 27 will be i=12, j=14, k=25, l=27?
other question.. If I have a plate formed by six shell square elements as in the image and would like to linearly change the thickness in the direction of the arrow I must create 6 sets of real costant going to specify from time to time the thickness of each node by calculating by hand the increment?
dmaz
you better manage shells with "sections" and not with real constants.
try to take a look at the online guide, chapter 16.2
the commands you should use are:
secreted
secfunction
Unfortunately there are no variable thick shell examples in the guide (at least I did not find it)
ps: see using shell181 that shell91 is no longer supported and documented.
Hi, dmaz.
Did you finally find out how to do it? because I have a shell structure to do, but they told me that to model a thickness change is better to define areas and then give these areas a different thickness to simulate this variation. then if you have to pass from 30 cm to 15 cm to create more areas and give for example a decreasing thickness up to 15 cm
