shift to the next face
  • Thread starter Thread starter Antodima77
Antodima77
Good morning to all, I have a problem with inventor 2017
I can not once take the 3d constraint command (axiemi environment) switch to another face than the first selected with the mouse scroll.
I can't change my selection.
Usually when placed on a face it allows you to select a set of possibilities, but I can't anymore.
someone managed to solve this problem.
Thank you in advance
control in tools ==> application option, in the general tab your configuration
here is how I use the command:_foto__653.webp
matteo hi your suggestion is correct , now works thank you very much for your availability
