shift work plan
  • Thread starter Thread starter fraribre
fraribre
Good day to all!!!
I have a problem I can't solve, so I ask you.
I created a worktop parallel to the main at a distance of 100 mm, on this floor I made a sketch and then an extrusion.
I then had the need to move the created plan (and therefore its objects) to 150 m from the main (then moving the 50 mm plane to the point of creation), but I failed to move it.
is it possible to move it? and if it is possible, how do we do it?
thanks in advance to all
france
click click on the worktop, opens a window with the numerical value that you will correct.
Bye.
Thank you!
I tried, I changed the value, and it only updates if I go manually to update the next processing.
I thought I'd see the plan moving right away, but I didn't.
Thank you very much, you are always fabulous!!!!
france
You just need to update, and how qunado changes the value to a quota, don't you update later to see the modified quota?
I don't use it very much, so frankly I forgot it, instead I have to reevaluate it.
Thanks again
france
