shock absorber design
  • Thread starter Thread starter nicola1985
nicola1985
Hello, everyone!
I'm designing an assor for my first-level thesis. . .
I created almost the whole model for fem analysis but I have some problem with hypermesh.. .
use nastran as a solutor then work with nastran template.
In particular I would like to model a 300kg weight plate and go push my absorber with a certain speed towards a rigid wall.. .
I shaped the plate but I can't figure out how to establish the contact between the plate and the absorber (now it passes on) and how to put a concentrated mass at some point. . .
Thank you!
a first-level thesis with fem, dynamic analysis, contact analysis and non-linear impact theory.. . ?
Hopefully... :wink:
how to ask the school exam guide to go on two wheels. . .
The simulation is turning now...
for the contact I used rbe2 rigid connectors, while for the mass I solved giving a mass to all the knots of the plate behind the assor using conm2 elements.
Now you have to see the results!
Well, I quote your signature. .
compliments for the intriguing. sincerely.
However, do not confuse courage with fearlessness.
In fact I was a little temerary to accept a job of this kind but although I lost about 6 months (to learn to use a cad, a preprocessor and a solutor) I am happy because the theses should all be so...
in these 6 months I was intern at a company where they helped me and where in a few days we will build what was planned. . .
Thank you for your compliments!
in a few days I put the video on youtube and share them here!
Good weekend, everyone!
so, but above all. . .
...so, history changes a lot.
I look forward to seeing the result and again congratulations :finger:
a static analysis nastran for a dynamic simulation is not the maximum.. .
rbe2 contacts are rigid...so they are not well especially for absorbers. . .
use dyna
I don't know what you're doing. . .
You have to do a crash?with nastran?scusa but I don't understand. . .
cmq the bolts you can do them with elements like beam...
crash analysis...
I used the function of nastran "bolt" that schematizes a bolt like so many interconnected rbe2.
I'm working on such a problem... I'm using ls dyna pre post... and also as a solutor. . I learned to hate him. I have made 3 components: the wall, the assor and a plate. I'll explain. if you make the absorber impact back, as it is right that it is, immediately after the impact with the wall and therefore you cannot establish the extent of absorption. moving a wall against the assor is not perfectly correct as you do not take into account the mass of the machine to which the assor is attached. Therefore, it creates a rigid plate that has the mass that you want, and arrange it coincident to the back of the attenuator. set a rigid wall and a plastic kinematics for the attenuator. contacts impose them between plate and attenuator with a set part and a single surface automatic. the same you do with a set part between attenuator and wall.
