shrinkwrap on combination configurations.
  • Thread starter Thread starter AlCa65
AlCa65
hello to all, need help for the following problem:
in a combination with n simplified representations, you import an external shrinkwrap as feature.
the goal is to be able to keep shrinkwrap visible only in some simplified representations.
a big thank you to those who can help me because my consultants couldn't do it.
you can't activate feature in simplified representations together, you have to "apply" to a part to do it, in practice create a new part in blank together and here in amounts the package feature, at this point you can activate/disable all the shrinkwrap you want.
If you want to manage it with the features you should use the layers.
I also tried the solution of the layers but I don't know how to handle them in simplified representations.
I thought: Is it not possible to impose a relationship between feature and simplified representation? that is to say that if I activate a date representation also the feature must be active or vice versa.
I think you're complicating your life, why don't you use a piece of support like I wrote you? Don't you want them apart?
