shuttle in dmu fitting
  • Thread starter Thread starter marcofa
marcofa
in dmu fitting environment
Is it possible in a joint with sub-assiems, after attacking the shuttle to a sub-assisted, moving it respecting the constraints with the other sub-assistances?
would it be possible to do the same in assembly with the manipulator?
and in dmu kinematic it would be possible to do the same with the manipulator instead of moving the commands of the simulation?
Mar
in product environment when the manipulator is hooked to the moving part (green handler) just press the button on the keyboard.
However, in the manipulation command, the locking of the alleys can be achieved.
There is no command that blocks the constraints.
or move the axieme by changing the bond parameters (change an angle or a distance).
by activating the automatic upgrade of the axieme, you can simulate cinematism.
However, you have two ways to test the mobility of a group, the easiest way is to use the command "movementation" (1):
movim.webp- you choose the driving direction (2)
- blocking constraints (3)
- you can insert the option "stop on clash" (4)
mov2.webpdragging with the pointer one of the elements, (except the fixed) this moves according to the rules of the constraints.
Alternatively you can try direct handling, dragging the compass on a particular (except the fixed), holding down the tast maiscolo, and possibly activating the option "stop on clash", movements according to the direction of the compas, according to the rules of the constraints
