GeiGei73
I ask you a little help to tell me whether the annex is correct or not. I have a request for automation for the opening of a door covering a cassone and, since the incoming data is unclear but I was provided with a sketch of the application, I wanted to verify that the cylinder they chose is correct in order to calculate pressure, flow and the rest of the implant in a manner consistent with the application.
According to you the verification of the necessary force represented in the attached design is correct?
if I wanted to calculate the force required to the cylinder based on the angle and weight strength would be correct:
fcil = fpeso * (b1 / (b2 * sin (alpha)))
where:
b1 = horizontal component of the distance between point a and centre
b2 = distance between point a and point c
alpha = cylinder angle
Thank you so much.
where:
Thank you so much.
