simulation/expansion
  • Thread starter Thread starter alemonte
alemonte
I ask a question that I cannot solve with proes: I would like to subject the object that I attach you to a pressure distributed throughout the internal surface, allowing you to move only on the x-z plane and binding the long y. as you do?
thanks in advance
alessandro
thanks in advance
alessandro
with the only cad I doubt you can do it. . .
I'm not sure. . .
but to logic rigor according to me you should stop it above and below with a surface, then when you are in simulate bind the move to these two entities.
the result would be a kind of bang but and I don't know if that's what you want to get
I am trying to bind it on the upper and lower edges but tells me that there are missing constraints everywhere
I know this was my problem, I think there are some boundary conditions that escape me and violate the rules of static analysis.
simply bind the structure to one point only with rotations and blocked movements.
the load you used is not correct... you need to use pressure.
see pdf attached.
I hope to be helpful layer
see pdf attached.
Okay, thank you very much, I'll try now!
I take advantage of it to wish good holidays to all users!! :smile:
