gerod
I am trying to understand the correct simulation method for structural analysis of a complex frame.
realize to take a hull of a boat and build the frame with tubes of various sizes.
Now, I tried to set the 3d in ansys ds but there are a number of problems on geometry and the mesh does not do it (the geometry has singular points or, being the tubes not perfectly combo, there are volumes that come up, etc.): the error is visible with the wireframe activated but I can't find it (they had put a visible flag!!!) also because we are talking in a frame of 30 meters x 15 x 1.5 and finding the millimeter that creates cases is difficult.
admitted that it can reconstruct the geometry and maybe arrange the joints between the tubes (the tubes join with skewer axes and therefore the union can give life to elongated -triangoli elongated surfaces - that give problems on the mesh).
the question: I was asked (from the dealer ansys) to use the mechanical version (I don't know which, but the version that also manages the beams).
some of you obviously will have used this form and therefore I would like to understand if it can actually go well to simulate frames but, above all, if it is simple to use or serves to make a course.
I never used it, so I don't know.
If the frames were regular I would have no problem in the simulation, I would do it with the ds structural version.
My fear of using beams is that I could lose some details on the joints, on some plates that have their interest in the calculation.
I can't put an example of the frame, top secret. imagine so many interlaced tubes that follow a profile of a hull.
