Davimont
Have a good night.
I have a circular plane that rotates in a way scattered on bearing spheres and maintains its position on its axis thanks to two tubulars that rotate one within the other, I schematized the components in the image.
the table must be blocked by one or two pneumatic cylinders while the operator works and must be able to unlock the rotation to the need.
cylinders will be equipped with a buffer on the stem that presses on the green tube.
I had chosen a 27 series camozzi cylinder from ø40 double effect but the customer asks me if it is possible to have a cylinder that presses and blocks the table we say passively.
even in the absence of air, the cylinder should press on the board thanks to a spring, while the air should only serve for release and therefore to bring the stem back.
the race must be minimal, just to lock and release the tubular.
Is there anything like that?
the table must be blocked by one or two pneumatic cylinders while the operator works and must be able to unlock the rotation to the need.cylinders will be equipped with a buffer on the stem that presses on the green tube.
