single and total weight
  • Thread starter Thread starter Alex70
Alex70
Guys, I need to remember how to do it because I did it in its time but I don't remember anymore.
How do you recall the total weight of the parts to q.ta greater than 1 in the table? I explain better: pro-and draws the weight of every single part present in the axieme as if it were one, but if I wanted the total?
thanks in advance
found.
to the table, through the menu' repeat region, you must add the following report:
if rpt_qty=
weight_tot=asm_mbr_pro_mp_mass
endif
then you have to add a column to the repeat region where the parameter &rpt.rel.peso_tot is recalled.
the game is done.
I hope you're useful.
Hello everyone
It's not like you have an example you can attach. because I tried but I can't.
the most would be that you attach a drawing that double-mounts the same component.
otherwise the only table file is good.
Hello and thank you
to me by mistake (a valid symbol 'asm_mbr_pro_mp_mass' was found) on the string peso_tot=rpt_qty*asm_mbr_pro_mp_massho agito così:
if rpt_qty==1
weight_totale=asm_mbr_peso
else
weight_total=rpt_qty*asm_mbr_peso
endif
Dove weight=pro_mp_mass in part relations
Hi, I'll get you a table.
you have to update the references to the part parameters you use (denomination, code).
I have:
weight=pro_mp_mass
weight_g=weight*1000
then in the table reports you have to put:
if rpt_qty=
weight_total=asm_mbr_peso_g
weight_total=rpt_qty*asm_mbr_peso_g
endif
  • peso.rar
    peso.rar
