single cable design
  • Thread starter Thread starter Ale Sognatore
Ale Sognatore
I've always designed electric motors, but I didn't need to create complicated cablings, I was riding with simple assemblies of cables and connectors. I am now creating for the first time to create permanently assembled cablings, connectors, terminals, but with cables passing through also tubes, ties and ferrites, and with various directions.
having never used the wiring environment to directly create the cables from the assembly, I tried to use it but I did not really succeed.
Does anyone know how to explain to me?
Thank you in advance.
ale
I also have the need to represent the cables in my projects, but I do not use the wiring environment, I simply treat them as parts.
I'll give you an example, I hope you can help.
Hi, dani,
being the first weapons and therefore novice of the cablings with creo 3.0 how can I define the points for the various trajectories, as from your example? I always dwelled on the engine as a mechanical part but never cared about the electric part.
cables must connect connector terminals with free terminals, from ferrite to tube
then I will have another 6-way connector connected to another 6-way connector.
from the image you have attached, it seems to me that your cables lie on one floor. if this is true the thing is very simple do a sketch with the path that interests you. otherwise you must change or add the coordinates of the reference points until you pass the curves where you want.
...being at the first weapons and therefore novice of cablings with creo 3.0
I repeat; My method does not use the wiring application, I just need to evaluate the cable paths and their encumbrance, so I simply model the parts, using all the features available.
the wiring without the ad hoc package, you can manage precisely as parts, I normally design on 2 floors the curves (maybe from the top and side) and then project the curves together, with the resulting 3d curve, I go sweep and concludo.
attention that the most complex trajectories, are to be created with more 3d sweep tangents among themselves, thus resulting from more curves.
Hi, dani,
I created parts from the 3d and then I did the continuation of the cable with points. Here's the result. I don't think it's the best way but buffer not having the wiring modeling package
if you need to represent the cables to evaluate the encumbrances and their passages, it's more than good.
hi dani I forgot to attach pictures
