sinusoidal force for structural static analysis
  • Thread starter Thread starter fabioing87
fabioing87
First of all hello to all, it is the first time I write on the forum but I have been following you for some time.
I have a problem, perhaps banal, but I cannot solve:
I have to check structurally a frame formed by tubular but not constant but sinusoidal force, that it varies over time from a positive value to a negative (so as not to know how to read and write), then when I accing on ansy alongs wb 15 to insert a force, select the face to be applied, the direction and then in "magnitude" selection "tabular data", then copy my parameters of time and strength this situation can lead to invalid results or solver pivot errors. consider changing to full integration element control or meshing with more elements. refer to troubleshooting in the help system for more details............................................................................................................ ?
Thank you very much for your help
