ragnol
problemone (do not raise your eyes to the sky, come on....)
in autocad 2019 is it possible to avoid that the icons "cut" and "extended" are nested?
It's a bit of a break, having to open the curtain and change the command, so: can you have the two separate icons like "Once"? Do you have to customize the icon bar?
ps: is there a philosophy behind the choice of autodesk to shorten these two commands? I mean, it's obvious that while one draws a little size and a little stretches, and it must continually change command...here, why did they do it?
thanks and good day
thanks and good day
