Hello, everyone. I want to insert the dimensions (width and depth) in the abacus of the pillars but does not allow it. gives you the possibility to enter only the volume.
Any help?
do you refer to structural columns? yes the answer is yes, for these elements you use the name of the type, not the width and depth. the name of the type contains the size (for concrete columns), and for steel columns the name of the type is also used only. you need the numerical values of the depth width, you need to change the parameters within the family, using shared parameters instead of family parameters.
