MBT
bha... objection to your honor.according to me the pneumatic solution generates vibrations at the ends of the race that destroy the coating...
electrical actuators are softer.
as for all things, depends on the components you choose.
you can take progressive start valves to start the cylinder gently. you can use a plc to control the position and adjust a proportional valve. you can think of using the end brakes of the cylinder properly calibrated. Clearly it must be "brand" stuff... if not you really risk having vibrations.
but the same risk you have with electrical actuators controlled by inverter id bad quality etc etc etc etc.
