sizing of a mounting
  • Thread starter Thread starter caprox
caprox
I wanted to ask for lumens on a problem that never happened to me until now.
I'm checking with ansys wb a strut to l imported from inventor included within a frame on which insists a pressure along the axis z (which is also the axis of the above-mentioned mount). At the time of the verification I get very high values, but only in an infinitesimal point in the rest of the mount are abundantly within the limits allowed, this is symptom of some problem.
Now, the question I wanted to ask is as follows: Is it possible that imperfection is due to a bad import of the model? or is it a bad setting of the boundary conditions?
give me your opinion. I thank you in advance for the help you want to give me
Maybe a plan to understand would be appreciated.
In principle depends on the mesh you do.
If you make a thick mesh it is likely that the voltage values on certain elements are high.
You're right. I apologize. I try to send it today when I get back from work.
In fact the mesh is a little small, around 100 mm, but the problem is that I have very big pieces and small pieces so I chose something convenient to mediate the two situations. However I will send a schematic
Thanks for now
