pierp.flour
Hello everyone, they are struggling with an exercise that concerns the static and fatigue dimensioning of a lazy-cremagliera system for the drive of a sliding electric gate.
Sorry if I start a new discussion, but I found nothing exhaustive in this subsection of the forum.
as data I have:
-band width;
-power of the engine;
-reduction ratio from the engine to the pinion of the system to be dimensioned;
- maximum painting, electrically limited for safety reasons;
-gate run;
-Mass of the gate;
- number of wheels on which the gate rests and diameter;
-coefficient of wheel-binary friction.
As for static sizing, I assumed that the maximum thrust on the gate was equal to the tangential force to be used for the static sizing of the wheel. having noticed the band width I obtained from the static calculation in contact hertziano the number of teeth required, going to check it then with the formula of lewis.
no problem.
when I go to make the calculation of the tangential force from the friction couple (known by the text as the only strong couple), calculated on the wheels of the gate in contact with the track, I noticed that it assumes a value greater than that I used for static sizing.
from this emerges the question, it is necessary to use the relationship of reduction of the motor, the power of the motor and the maximum speed of translation of the gate, or simply, can not be considered legitimate and I wrong to enroll in mechanical engineering?
thanks in advance to those who will answer
as data I have:
-band width;
-gate run;
-Mass of the gate;
no problem.
