Trotto@81
if you want to draw two contiguous semicircles to form a circle, but with the characteristic of being on two perpendicular planes, how could I do without using the sketch copy command to use the first semicircle as reference to hook the vertices of the second?
how do you behave in these cases?
I used the example of two semicircles to make the idea, but it could also be two splines.
