sketch odds, fixed or variable character height?
  • Thread starter Thread starter malf
malf
Hello, everyone. I was putting on a question... When I insert sketch odds into a sketch of part or axieme, the height of the character remains fixed on screen, even by zooming. Other times, however, apparently quite randomly, the height of the character of the quotas is scaled with the zoom, similarly to what would happen in draftsight odds, for example.
in the latter case it is necessary to zoom, often, to read the interested quota. 2017-05-07_093846.webpNow it's been two days that I'm going back to the window of options in the long and wide, but I can't find the setting entry that adjusts either way. Also it would be useful that, in the first mode, with always fixed-size quotas on screen, I could set the height of the character, to make it barely readable, while, usually, it is huge.
menu tools>options>property of the document > details >text of the same size
It's only worth that design. modify the model for always having it in the same mode
ah, thank you! then selecting "text always in the same size" the text does not follow the model scale, but remains fixed.
and to change this fixed dimension? boh, maybe you can't do it.
Thank you. I didn't realize that the quota settings were also for the sketch quotas, I thought they were only referring to the quotas of the table. I had considered the sketch quotas in the parts only as a symbolism own and internal to the software, in the manner of how plans or aces are indicated, I did not think if it could decide the style:redface:. Then I can really change all the quotas! :finger:
in the options there are two main cards:
System options: apply to each file type you are using
Document options: all these settings apply to the specific type of open file; i.e. part, together, drawing
among the tutorials, what I recommend to do, there is also that of customization of solidworks
hi massive, after I read your msg, I went to see in my options, but the check you said didn't let me select it. did not appear, so do not resize the text according to the zoom. I have always used so and even if sometimes some display problems I have, I think it is not really serious. But I'm curious to know why it doesn't make me set it up? Do you know?
