by environment 2d you mean at table .slddrw?Good morning.
question by beginner:
is it possible to make a sketch on a face (as in figure) in 2d environment?
or possibly do it on the 3d and then "activate" the display on the 2d?
You have to activate the sketch display and tell the feature manager to show you that sketch in that view. look at the image:I do not know how to view it on the table.
Of course, because as I said before that sketch you are doing it on the table, on the sheet plane. you can tie it to a view but it remains in 2d on the sheet.I also tried to do it directly in the drawing environment but the sketch remains always to compose to the sheet of the table and does not tilt as if it was placed on a 3d supex (as from image attached earlier).
it works! thank you 1000!!!!!! and good Sunday!! :smile:You need to activate the sketch display and tell the feature manager to show you that sketch. look at the image:View attachment 23328Of course, because as I said before that sketch you are doing it on the table, on the sheet plane. you can tie it to a view but it remains in 2d on the sheet.
Marco:smile:
