sketch on isometric view 2d
  • Thread starter Thread starter Hope
Hope
Good morning.
question by beginner:
is it possible to make a sketch on a face (as in figure) in 2d environment?
or possibly do it on the 3d and then "activate" the display on the 2d?
Have a good day!
Good morning.
by environment 2d you mean at table .slddrw?
in case yes, you can do both things (the second you have already done it in the example). with the difference that what you sketch in part 3d you can view it at the table, but not vice versa; binds to a view but remains there on the drawing sheet.
Mar
Hello, thank you for the answer.
I do not know how to view it on the table.
I also tried to do it directly in the drawing environment but the sketch remains always to compose to the sheet of the table and does not tilt as if it was placed on a 3d supex (as from image attached earlier).
You have to activate the sketch display and tell the feature manager to show you that sketch in that view. look at the image:SCHIZZO SU 3D.webp
Of course, because as I said before that sketch you are doing it on the table, on the sheet plane. you can tie it to a view but it remains in 2d on the sheet.
Marco:smile:
You need to activate the sketch display and tell the feature manager to show you that sketch. look at the image:View attachment 23328Of course, because as I said before that sketch you are doing it on the table, on the sheet plane. you can tie it to a view but it remains in 2d on the sheet.
Marco:smile:
it works! thank you 1000!!!!!! and good Sunday!! :smile:
