sketch together
  • Thread starter Thread starter AndreaG85
AndreaG85
as from title, I wanted to ask you if it is possible and how to create a sketch in a set. I would need to check for positions in various parts.
I tried using the available features and didn't create any problems.
in sketch -> start sketch 2d I decided the plan to build, after projecting geometry I made a rectangle aligned with the existing wheels6.webp7.webpIs that what you meant?
a greeting
@fabiosam My problem is that I can't, together, edit a sketch if the position is not that master. instead I would need to do it when the aid is in other position, because I saw that the sketch does not follow the points
solved by creating a sketch inside a subaxieme. and modifying it once placed the assieme father
