Gio_S
Good morning to all, yesterday, as I usually do, instead of with the week enigmistic I devoted myself to my favorite puzzle with the analysis of the coding of graphic formats.
the file type sld is not document, or better I do not find it, and I am at the very first pass.
It's a vector file.
- has a header (in fact incorrect to call it so because as a whole that I isolated as a repetitive it certainly contains info on the graphic system in use), but a certain fact is that the plotting, attention, in my elementary case of lines to be traced with which I started, begins to byte 34°
- then I find 2 byte(short) + 2 bytes per x,y of departure (with origin 0.0 low left), with 4 hexadecimals per axis, to be read from the last.
- then, consecutively, another 2 bytes + 2 bytes for x,y end line
- then two bytes detachment from the next line (color? for now I don't know)
Actually, I don't even know if they pull the pen or they say it goes on. for now I analyze two separate lines.
- Finally 2 bytes per fine file.
It seems quite elementary to build. I will make us a small bitmap vectorizer, like what I use for my works, which transforms pixel lines into solid color (small packages cad optimized by 16 million)
that I need for my scanning work photos trains for 3d printing purposes, slds for now are just like fun, maybe I will need to correct the menus starting from bmp.
If by chance someone had more information on the format coding thank you!
It's a vector file.
