slow display constraints.
  • Thread starter Thread starter xxfast
xxfast
Good morning, everyone.
from a few months, the company where I work, installed sw 2012 and I found a significant slowdown in the display of constraints.
every time I try to display the constraints of a set, the program will pop up for a few seconds in displaying the contour of the parts corresponding to the constraints.
before we had sw 2011 and this problem did not show up.
I don't think it's a PC performance issue, at most it might be the graphics card that doesn't seem very prettier to me.
Can someone tell me what this problem depends on?
:bekle:
:bekle:
is it not that you may have changed or changed the setting in performance options, to view the constraints you want to see when you want to see the couplings that has a part using the command "view couplings" that makes you see only the interested parties? in this case could be because it makes the transparent parts option that I think you can turn off in the options.
That's what I mean.
I'll look at it in the morning.
Could you tell me more exactly what option I have to set up?
That's what I mean.
should be in general system options > selection/visualization, but I'm not sure I had read that you could do, I'm sure you can do when you edit part, I never had problems I never touched anything :biggrin:
I'd start with this settling.
Okay, mike.
I was on transparency force, now I put on opaque, it seems to me that some small improvement there was, but the problrma persists.
from my personal pc the thing does not happen.
I think it's a performance problem. . .
Okay, mike.
then I suggest you import the system settings of solidworks from the home computer to that of the office. (only system ones).
backup, as solidworks suggests, so you can restore them.
I tell you this because I noticed (in various blasphemies) that swx 2012 has the peculiarity of ruining this file (.sldreg).
I've been through all the colors lately, from p&g that don't work at bad visualizations of sketches in part/axieme environment.
I always solved by uploading the .sldreg file of another computer.
Okay.
But I would like to know the procedure to import the settings, as I do not know this procedure.
Also on my pc I have the 2011 version, while at work I have 2012.
