slow down.
  • Thread starter Thread starter PICO
It seems that I solved with the 2013 version.
probably deleted some files by uninstalling the old version.
rather I don't work express tools.
I see them all active in the All-In-One bar, but if I try to use them, it tells me "unknown command".
as to slowness, for now it seems better to split the file in two and putting the heavier one (with sections and planimetries) as superimposed xrif.
Better than nothing... at least I can move on... .
Domandona.
Now work is running pretty well.
But I noticed that when I make the block editor everything starts to slow down. if every 4/5 edits close the file and I reopen it all quickly.
I think it's due to the undo memory.
is there a command that allows you to clean up your memory or limit the undo held in memory without having to turn off and rekindle every time? ? ?
seems to me the variable undoctl .... try to search in the online guide.
I don't think that's it.
already is in read only, sorry ...... You have to excuse me, but I've never placed the problem, so apart from that distant memory I had of that variable.
But if you type the command in full?
or undo > control > none ......
one of the undo command subptions I mean:)
I was referring to the grapes.
I was always me, but the problem had never been so serious... .
but.... the reasoning that made gm was and was sensible, but I never had this kind of problem, at least not so serious, and to what I see there are not many complaints also from other users, so.... :( I don't know what to tell you.
working with xrifs, I think I can say I've solved it.
The only annoying thing is that when I load an xrif, it puts it in the wrong scale and where it seems.
Where am I wrong?
