slow left key after input keyboard command
  • Thread starter Thread starter onoc
onoc
Good morning to all fellow caddisti,
I have a nice problem that is really annoying and prevents me from working smoothly and quickly with autocad.
work a lot with the keyboard for commands moves, copy, line, circle... etc... etc... the sending of the commands then I give it with the space bar or with the right button... depends... I don't even mind, and so far everything is ok; at this point the problem is manifetsa, clicking the left button to run the command is how slow to recognize the same.
then: by typing a command (e.g. c), sending with the bar and immediately clicking with the left button to run the command, the latter does not respond immediately (as is right it is) but after a few seconds... It's like she doesn't recognize the command right now, and she recognizes it after a few seconds... you understand that working in a sent way you have to slow down because the left key is activated after a few seconds, the problem is really serious... I thank everyone in advance and hope that someone has the same problem that has already solved.. .
p.s. if I click, for example the circle, from the toolbar: everything ok; the left key immediately responds as it is right that it is... Everything is really weird!
cone
