slowdown and unrecognized message
Federico.P
Good morning.
on autocad lt 2014 different designers in the study in which work find the following problem:
opening multiple designs simultaneously autocad slows down dramatically and in the passage from one file to another you see a "scrowd" of the interface or in the lower right they appear and disappear quickly of the "unrecognized" messages.
This happens independently from the size and content of the files (usually it is two-dimensional drawings of furniture, nothing particularly heavy).
We seemed to have identified the problem in some non-standard retinals, but the problem arises regardless of this.
the machines on which autocad turns are all down new, with picture graphics cards, good ram equipment and ssd discs.
some are even hp workstations just purchased. I would exclude hardware problems.
Did someone find similar problems?
every suggestion is well accepted.
You should understand if the graphics cards have particular characteristics, not compatible with autocad, or you have to turn on or off the graphic accelerator
Thanks for the answer.
the graphic accelerator is activated and nothing suggests that it is a hw problem since it presents itself with some files only.
projects also of considerable size have no problems, other drawings of a handful of lines are unmanageable.
I assumed there were elements of autocads that created trouble, e.g. retini.
One of these files should be analyzed that is problematic.
If you can tie one.
I could create some problem, it is custom-made furniture for a customer.. .
I don't want to risk any consequences.
I understand it's hard to hypothesize without seeing the files, I was interested to investigate if someone had a similar problem.
Thank you
