Brethil
I write because I am affiliated with a problem that I can districate; more practical-organizational than technical.
basically, I'm a single user; I do not use vault and until today I have created multiple structured projects in order to contain folders like: assemblies, parts, drawings; projects which then copied all *.ipt files from a generic folder "free parts" which served as a supplier of parts for each project folder.
and so far I have never had problems; apart from the fact that over time I began to have a bang of projects full of zeppi parts.
then came doubt; The atrocious doubt. .
one of the needs to change to a part *.ipt that is fixed present in all projects...and immediately I realized that to do so, now as it is now my task to open every project and make the changes every time to the same part, or cmq change that of the "free parts" and then replace it in the projects in such a way that in its set you will see the appropriately modified part. . .
I wondered what I asked myself....but if instead of organizing the work in the state I had created every project always using the parts directly from "free parts" I would have just changed that piece once and then find the change in its " instance" in every project; I would have had project folders without *.ipt files and then read more. . .
Could I be wrong? Is there something that escapes me and I can't grasp?
Is there someone expert or who has already banged the horns that could direct me?
My projects range from 200 to about 1000 parts.
But I don't know what fish to take. _
thanks in advance to all.
:smile:
:smile:
