smooth retinals are not seen correctly
  • Thread starter Thread starter ezio.zanoni
ezio.zanoni
Good evening, everyone.
I've got a problem with the snails.
I designed some snail retinas with autocad 2007 and I only see strange spots.
I tried with the screen lcd asus vk 222s (22" 16710) resolution 1680x1050 both with video card ati radeon 4650 and also with video card ge force .... .
the same retini, with autocad map 3d 2009, on other pcs and other screen I see them well.
Is it a matter of setting up?
thanks in advance for the help.
exact without even copying it as you use dropbox (net space). the only difference, apart from pcs is the screen that at home is 16/10 in office 4/3.
I think I have identified the problem (at least the topic).
as drawing with georeferentiated photogrammetrics, it happens to draw the restraints very far from the origin 0.0.
the defect is probably linked to the insertion point of the retini.
even if the mask of insertion of the nuggets does not preview neither for 2009 nor for 2007 the skeletal of the insert point (for normal restraints you can choose for all two versions) evidently for 2007 is a problem to draw restraints away from 0.0.
If so, can the problem be circumvented?
a bit twisted the explanation but I hope in your intelligence.
