hi to all, I would need a council to model in rhino 4.0 the attached sofa (of ron arad, called victoria & albert) because I am trying to create the sitting block with the sweep command to 2 tracks, but I have problems to model it.
make a normal ring, then with the control points move the surfaces to get that shape, maybe first in the plane, then by the thickness and fillett. with tspline you take two minutes.
