Well, you're just gonna say, you've chosen a nice pear cat.Who can give me a few tips to shape this couch?
I'm in serious trouble and I can't combine anything!
Thank you:
Hello, Marius, thank you. Is that a demo file you sent me?Well, you're just gonna say, you've chosen a nice pear cat.
I can give you an idea of how to set it, in the enclosed rhino file you will find curves (red and green) select them all and then from the _networksrf command.
the result must look like that of the image.
Once you understand the method, you will have to adapt it to your sofa.
good work:biggrin:
I can ask why you need to model it, being that sofa already in production, so already designed?the project has already been done and the sofa already production, I just have to model it in 3d...
Because there's no 3D file and the company needs this file and others I'm already doing and I'm going to have to do it, but this kind of sofa I don't know how to modelI can ask why you need to model it, being that sofa already in production, so already designed?
I have no idea how much, and especially if, they pay you by doing an internship. but model it from scratch to have a 3d that does not serve for design (I imagine to make renderings or similar things), with the availability of the already made sofa does not make sense. make a 3d scan that in the end costs less (always pay you...) and you will have the model in a very short time.Because there's no 3D file and the company needs this file and others I'm already doing and I'm going to have to do it, but this kind of sofa I don't know how to model![]()
We try to understand the purpose of modeling, since it's already in production.Anyway, guys, I have to model it in rhino. I only have this in the middle. encourage me![]()
:finger:Let it go, with rhino it is very difficult to make the submerged buttons in the pillow, I did some tests. Look at me. qui as are the techniques to make this type of objects, there are various software, but the technique is very similar, there is also something for tspline, but no buttons, however the system is the same. with clayoo or tsplines (try both from 30 to 90 days) you create the seat, where will be the buttons, then define precisely where will be all the points, then the polygonal subdivisions will be consequent to this, around each point you have to make a polygonal circle, adding points of control, then deepen the point translating it down, so you can try the button, in short, leave a little space, the folds otherwise take a piece of sofa between those placed above, size, add, scale etc., and the same is fine.
