sokidworks 2017
  • Thread starter Thread starter tanticapelli
tanticapelli
Here I am again. .
I would have the possibility to install sldwks 2017. since the last works are on 2016 sp 5 if I install 2017 I would rejoin to open those projects on the new software?
or should I keep both versions installed?
Thank you!
so many hairs
each version quietly opens the files saved in previous versions.
in recent years the last relegation of a version can open the first of the next one https://www.cad3d.it/forum1/threads/23289-salvataggio-per-versioni-precedenti-solidworks?p=401880&viewfull=1#post401880
if you don't have any particular problems you should keep both versions* and possibly make a backup of jobs in 2016 to keep them in that version because then if a customer or supplier asks you the file in 2016 you are fried
*Just be careful when installing the destination folders otherwise you are with solidworks corp e solidworks corp (2) and when you manage the templates or various paths you risk to confuse yourself and make a slaughter
