Ciuchin0
I created a complex system of beams as from attached image.
These beams have for the moment the upper ecstasy equal to the ground level.
to these beams, I should "overtake" a lotion. .a sort of plate that will then host the inner area of the lot, which will be used in part to green and partly to pavement.
How do I achieve this "higher sun"? I used the structural floor system. I need a ceiling in predal plates for precision. I don't understand. Do I have to create a floor for each area bordered by the beams? I'd be crazy. .
Can I do a "super solace" by taking the outer contours?
I did this, and he created me the supersonic but from the ground floor plan I see all the lines of the beams. What do I do? give an offset to the beams and lower them necessary?
for the differentiation of sucessive pavement (green or bettonelle) I thought of using a second floor overlapping to the structural one. but the latter. How do you want to do that?
thank you for the advice and hope to have been clear.
ps: I allow myself to add a question since from the drawing you see. the walls that house the ramparts of the garage, are interspersed with structural pillars. to avoid notice that effect of material difference, how should I act? Can I change the material only to a pillar face? or should I move the wall in front of them?
Thanks again.
Thanks again.
