sole transparent becoma
  • Thread starter Thread starter gio.max
gio.max
Hello.
I was working with revit 2010 and from one moment to another I found the semi-transparent suns (see photo), without understanding why...
If I make a proof of rendering it is all ok, the floor is matt with the finishing I chose, and the style "shading with edges" is skillful.
What did I inadvertently touch?
should exist in the forum a discussion about it: if I don't remember badly it was caused by drawings originating from the 2009 version.
I don’t think it’s my case, the design was created from scratch, only with revit 2010, I’ve never had a 2009 version installed on any pc. I just recently passed from winxp 32bit to w7 64bit, but still worked well with the new operating system for a plentiful month.
this is the image seen from below, in practice if I look at the ceilings everything seems normal.
I've been working with a project imported from 2009 to 2010, but I have to say I don't mind at least knowing what's under. check with the state of detail and color with profiles.
solved!
simpler problem than imagined, the upper floor finish had become transparent to 20%. reporting to 0 the value, the soles are back opaque.
