solid creation for 3d printing
  • Thread starter Thread starter mancio1988
Probably you're wrong in export, I don't see anything, just a few lines.
try in .stp or .step or in .stl (although in stl I don't know if I can change it) you send equally
Here I was then to export it to .step or .igs I had to open the original sketchup file with rino in trimmed planes and not in mesh otherwise the export did not make me.
now in this way I managed to export both in .step, and in .igs and in .stl
I'll coach you everything and see what you can do with it, as I said I have to print in 3d so I need a solid tin to get no mistakes.
As for the measurement of the project I believe that the width of the base has remained unchanged will have a measure of about 32.5 mm and a length of about 46,5 mm. I checked and it seems to me that the files I'm about to import below respect these measures, contralla as well but if you approach it leaves as it is the important thing is that the file does not take a scale amisura otherwise the result will not be correct!
here are the files:
View attachment file.rar
perfect I rechecked and it seems to me that the size is correct on the files that I attached to you so export should not have changed anything!
Here I am, I took your stl file, and corrected it from all the errors that were there (and were several!)
now the sl I send you should go well for 3d printing (I mold in 3d so you can trust)
I don't really know how to thank you, tomorrow I send you to the press and let you know, you were very kind and especially fundamental for the success of this press! thanks also to all others for support and data advice!
then perhaps my problem in revolutionizing from 123d design a solid from an emidisegno by selecting the design area and the edge from "fulcrare" does not give me the uniformly selected boundary and does not activate the command of revolution because the polylines and the splines used to create the design do not unite well and never closes the area to select
