solid edge draft
  • Thread starter Thread starter amhafeez_1984
amhafeez_1984
Hello everyone
recently I use solid edge and need to figure out how to show a particular strain in a draft
explaining my urgent
solid edge v 18
windows 7
If it's urgent then we'll all rush!
when you make the table, on the first page of the wizard there is the option to put the table developed.
Hahahahahah, big beonedge.
However, new users must present themselves and have to study the rules well before.
It seems to me that you arrived, asked something urgently (among other things if you were doing the exercise dedicated on solid edge you would have done before) and even asked to do so.
next time more attention and education.
... welcome.
I am a Pakistani; for 9 years that I am in Italy and work as a worker but for a while I have begun to do a autocad course
Well, you didn't need the name. Just say what you were doing. That's all. I'll take your name and last name for privacy if you want. or you can remove it, just move to your message and click on it.
At the end, save.
done. Good job!!
other consideration.
usually in the forums, if a person asks for a solution and then finds it, it would be recommended to expose the solution found so that others can also use it.
So if you've solved it, you're exposing the solution. this is the philosophy of forums.
thank you for help but still I did not solve the problem and that I have a .asm file that I have to give quotas. but when I go open I can see particular development
It explains better.
Tell us what you want to do.
If you want to develop a piece (not an asm) you must first develop the sheet on the 3d and then, at the creation of the dft (guided) you have to choose "developed sample".
here select the reference plan and put on the table.
