gfix68
Hello to all I have to create the scale of which place the model, the mast that you will see at the opening of the file is created with a surface and then I added the thickness... now I should cut the piece but I need to "flatten" of course I can't because I can't create a sheet from that surface... there are other methods to create the piece and then can convert it to sheet and then stretch it?
Thank you.View attachment scala a chiocciola.zip
