euGENIO85
Hello everyone, I am new to the forum, my name is eugenio and I am a student graduating from ing. mecc. at the University of Catania.
Now let's go to the problem.
I am using inventor, I have both the 2008 and 2010 version (although in English :frown
, I have to play in 3d a rov (i.e. a submarine robot). the problem is that in the assemblies, I cannot fail to connect two solids (or, in general, to set a range within which you can move a solid ab). e.g., if I have a cylinder and a piston, giving the concentric bond I can align the piston to the cylinder, but dragging the piston, this does not stop at the end of the cylinder (no on the closed side or in the open side). How do I solve the problem?
with solidworks I could bypass this problem by setting the bond with a range of two values, can't you do with inventor?
Thank you all.
Thank you all.
