solid print with hidden edges covered
  • Thread starter Thread starter SuperMicro
SuperMicro
Hello, a greeting to the whole community of cad3d.
This is my first post and apologize if maybe the topic has already been discussed but I couldn't find any solution.
the problem is as follows: when they are in wireframe I set that the hidden edges of solids see dotted (interested display styles/ wireframes/ occlusive edges) but I can't in any way print them. when I try all the edges are continuous lines. I attach a screenshot of a simple parallelepiped print layout.
I hope I've been able to explain myself and someone can help me.
thanks to all:smile:
sure that the hidden edges are continuous lines and do not hold too thick to seem continuous?
or that it's not some other print setting to correct?
hi massive and thanks to the help, I think it is a set of autocad because already when I preview the lines appear continuous.. .allego screenshotautocad 02.webp
if in the press preview you see continuous is probably a set of print options, not autocad.
attach files and screenshots of print settings
in the properties of visualization styles in Spigoli settings Put on faceted edges
