simone9999
Good morning to all,
I'm a master student and I'm doing the thesis on wind turbines, but I can't create the solid of the shovel. I imported geometry from an external file that I can't edit.
the shovel is divided into cross sections connected to each other by two curves (leading and trailing edge). I created the lateral surfaces between two adjacent cross sections. I have to create the solid of the shovel with variable thickness, i.e. I have to divide the shovel into 4 or 5 parts with their inside constant thickness. I tried both the 'experiment' and the 'offset' function by creating an internal surface and two closing surfaces as caps above and below.
If you can solve the problem of zero-thickness body, the thickening function would be the simplest and most effective.
I've been working on it for a long time and I'd really appreciate it if anyone could help me.
Thank you very much in advance.
in case you do not open zip files:
- If I thicken two adjacent surfaces I have this error "zero-thickness (non manifold) body: the resulting intersection is not supported", so I alternated solids created with offsets with others created with thickening.
- the airfoil of the generated offset surface has open lines and not closed therefore I created other lines and surfaces to prevent there being holes. tolerance is set to 1 mm to avoid problems. the surfaces thus created do not seem to intersect, in fact they cook correctly, the problem is to combine the different solids (the one created with thickening and those with offset) in one. I have the same problem even if I merge only solids created with offset.
