solid187
  • Thread starter Thread starter salvatore87
salvatore87
I would like to know if the solid 187 element is suitable for thermal analysis on a joint between two steel plates.thanks.
the degrees of freedom of 187 are only ux,uy,uz and accepts an Temp as "body load".
this means that with 187 you do structural analysis to which you can apply a constant temperature (magari deriving from previous thermal analysis)
for thermal analysis the equivalent (the tetraheric element with intermediate nodes) is solid87.
