Mh2
Hi, I'm designing a fan for my four-cocker with the software creo elements pro 5 but I have a problem... I have made the limit blend of four different parallel sketches to give a faithful form to reality to the wing, but within it turns out (perhaps even rightly) to be empty... Is there a way to fill it?
I tried from the edit menu > fill but from what I understood it only creates a surface from a closed sketch.
I then tried with edit > solidifica by selecting all the pieces of the wing but fails in the generation of the feature:
How can I do that? Thank you in advance!warning: a unilateral edge was found in solidifica_2.
regeneration feature failed.
