solidwork costing
  • Thread starter Thread starter Matteofossa95
Matteofossa95
Hello everyone,
I open this discussion because I find myself in difficulty with the method of solidwork costing.
I have built with profiles of studs (banks etc.), and I would like through the computation to understand the cost of these structures according to the profiles used.
so I simply need to calculate the cost according to the length of the profiles and the material. (I give the value for each profile form)
from how the function is set, calculates the cost according to the type of processing of the material (holes, threads, etc.), but I don't need all this.
I ask therefore if you can calculate only according to the length, and how you can do it.
Thank you very much in advance
not hjo underhand constriction, but if it depends all on the length and not on processing it should be enough to create an equation in which you multiply the price for the length getting the cost.
create a global variable in which you enter the price
create a global variable in which you call the length
create another globlae variable where you multiply the two precedents. this variable can recall it in the file properties
Thank you very much for the advice, I try to solve the problem by following your directions! !
