rosma
hello to all , I would like to know if with solidworks 2009 you can save in previous versions type 2007 - 2008.
thank you ros
thank you ros
No!hello to all , I would like to know if with solidworks 2009 you can save in previous versions type 2007 - 2008.
thank you ros
Do you have a search in previous messages for a bilateral hernia?hello to all , I would like to know if with solidworks 2009 you can save in previous versions type 2007 - 2008.
thank you ros
Do you know how many people would like to "solite" keywords? ..the server would not hold:biggrin:p.s. for moderators: it takes the auto filter that to the combination of words "Save previous versions/e" automatically deletes the message
in autocad you can save even in previous versions without losing almost anything. I say almost because if you use delel new functions these do not work (see springs etc).No!
as for all cad 3d and as it has been said hundreds of times in as many previous messages (now they also know the stones). use function research and read the rules.
Then if you have the program, you should know. .
Mar
vabbè, autocad e il dwg/dxf c'entra come i cavoli a merenda... I would also like to see that he could not save backwards a series of geometric entities totally untied.in autocad you can save even in previous versions without losing almost anything. I say almost because if you use delel new functions these do not work (see springs etc).
p.s. I know that autocad is not parametric etc etc., however I wanted to make this clarification.
bye
That's what everyone knows. always.in autocad you can save even in previous versions without losing almost anything.
autocad is the real cad 3d and is a Mr. Cad 3d.That's what everyone knows. always.
but we were talking about cad 3d "veri" :biggrin:
Marco:smile:
Look, even if she was born before doesn't mean she's the best. of 2d programs there are several. as told by colleagues here we talk about 3d mathematicians and not trivial geometries 2d untied among them. if it were as you say then inventor who is a 3d cad and always autodesk product should allow the rescue of 3d models in the previous versions. Does that prove to you?autocad is the real cad 3d and is a Mr. Cad 3d.
Autodesk was born at the end of 1982
the dassault systèmes in 1993 (11 years later)
the parametric technology corporation in 1985 (3 years later)
Okay, after starting flame escape:tongue:
ciauz
autocad... is it a cad????? :biggrin: for the love of God...:biggrin:autocad is the real cad 3d and is a Mr. Cad 3d.
ciauz
rotfl! better than a joke; Do you know anything else like that? :biggrin:autocad is the real cad 3d and is a Mr. Cad 3d.
you and just dassault and ptc tested their first beta3 they found 100 years ahead autodesk all in a bang.Autodesk was born at the end of 1982
There's no problem, with your flames, I brought the steam crusher's boiler to the temperature. :smile:Okay, after starting flame escape:tongue:
make the plumbing schemes (the one you can do with autocad) or the seedlings and prospectuses for the houses.autocad is the real cad 3d and is a Mr. Cad 3d.
ciauz
years ago before moving on to solid edge for reasons related to files made with an old cad 2d (a certain pj2) in the office I used bluecad 2.0, it worked rough as autocad and the cost was 100 euros or little more. If I have to spend 1000 euros or more for a version of autocad, surely and to closed eyes I would buy a 3d as for example alibre where besides saving money I have a 3d parametric cad.make the plumbing schemes (the one you can do with autocad) or the seedlings and prospectuses for the houses.
for the mechanics it is better if you let it lose ... I have seen of the bowls but, worse than autodesk there is only think design. :biggrin:
mha, personally autocad seems to me a discreet 2dmake the plumbing schemes (the one you can do with autocad) or the seedlings and prospectuses for the houses.
That's why I talked about patterns... because the 2d can stay.mha, personally autocad seems to me a discreet 2d
absolutely a bad 3d
on thinkdesign.... deserve academic kiss!
more than anything else has had the merit of creating the dwg format which is one of the most used for data exchange 2d between different cad.Well, come on.
they felt worse in the "cad comparisons".
However, fanatics aside and speaking objectively, autocad is the most widespread, but not necessarily the best of the 2d
to read the forum of revit it would be said that in the architectural field it urgently serves someone who knows what a plm or at least a parametric cad.That's why I talked about patterns... because the 2d can stay.
but let the 3d and the mechanics stay.
I am convinced that if a software house like dassault or ptc were to develop a bim on their kernel would be infinite pains for the autodesk.
I didn't know that, but I knew that they changed or rewrite a tot in progress.they had a tragic past with mechanical desktop, with inventor they went almost worse, so that there was a ongoing negotiation to use the ptc kernel (see that their is a bowl).
lisp lisp lisp lisp lisp lisp lisp lisp lisp lisp Who has a family of oblique walls? Who's got a tilted wall, who's got a leg cut?to read the forum of revit it would be said that in the architectural field it urgently serves someone who knows what a plm or at least a parametric cad.
to pull up four walls and make two ladders out of standard seems to be crazy.
