omec
it is possible to open the designs saved in 2009 version with solidworks 2010-2011
But it is absurd that you cannot save the files for previous versions.... probably because so "obligate" in a certain way to update it.Yes absolutely, but not the contrary.
quoto, if only we look at what happened these days only for the difference of service pack...probably the problem is more due to the implementation of the functions with which models, for example if you use the sheet module of 2012 save it compatible with an older version where those new features would not be impossible when you open that file to be able to upload them![]()
