weldox
I wanted to ask for information on this:
I noticed that when I apply a weld of asses, it appears to me in the section "circular" (a complete circle). . .
the problem is that, in this way, the welding is propagated even beyond the faces on which adagia (in reality, for example if we take a v joint, the welding is confined to a almost triangular section. .. and can also be displayed in areas where the soldering should not be there (I attach example image).
does not exist the possibility of defining the type of section of the welding? so as to avoid the "default" of circular section?
http://www.cad3d.it/forum1/attachment.php?attachmentid=19124&stc=1&d=1296652129Thank you so much!
Mauritius
Mauritius
