solidworks 2018
  • Thread starter Thread starter FIGOR71
FIGOR71
Hello, everyone. .
kindly someone can tell me that setting I have to change to make the opening of the assemblies faster?
since I passed from sw17 to sw18 the opening times of a set have become unnerving. . .
should happen when you still load a set in previous versions. must rebuild all models according to the new version. once saved in the 2018 version the opening should be comparable to before. to avoid this discomfort there is the possibility to batch convert all its assemblies, models and drawings into the new version (as long as it is worth it) so as to open them all up to date in the new version.
I tried to save the aid and reopen it but nothing.. .
I noticed instead that if the parts of the axieme are open the opening of the axieme is fast. .
update...
even with open files is terribly long
have you updated to the 2018 version that hardware you have? often update the software compels to update the hardware too. i for example with 2016 and 16gb ram go to god I tried 2018 and thick are to the limit, I should update the hardware so I keep 2016
no, updated only sw from 17 to 18...
