solidworks double rescue
what is the software that opens .ipt and idw file extension?
However both in solidworks through bees is possible (and I do it for a long time) rename components within a set, rename the table with the same name and change the internal references to the views.
Sorry, I wanted to write .sldprt and .slddrw
Is there already a plugin or a macro that does it?
I ask you if there is a way of intercepting the command saves by name of the parts and the assemblies and automatically rename the relative table.
doing the pack&go of the table and in the window that opens to the column save in the name rename both files
Hello Masses,
I thought I realized he wanted to do it as an open file, without going through pack and go, which I was taking for granted.
I have suggested the pack&go because as it seems to me to make those passages only to save copies, not in modeling phase or other
for this discussion, however, would be to be faced on "interesting macro for solidworks", in the current discussion we talk about automatic exports.
Yeah, you're right.
can you move the posts or start a new discussion?
Hello Masses,
the operation I often do is to take a part that already has the table and reuse it for a similar component.
e.g. I have a tree with its table, I have to create a similar tree with few modifications (type 20 mm longer)
I open the part and do "Save with name" with the new code
In reality there is a way to do it but you have to start from the table, saving by name gives you the opportunity to rename the part simultaneously.. .
However, in the design phase I find it more practical to focus on the "parts" and to leave the software the operation to rename the masses on the table (in the end I will go to put in place the quotas you need)
This would speed me up the creation of similar parts. . .
Hello Masses,
in fact, you just have to pack&go the drawing, directly from the explore folder without opening the file, and it also includes the part; in the column indicated change the name with the new one and you have the copies you wanted
if there is the possibility to do it directly from the part/axieme much better my workflow
we see if there are some plugins/macro that will...
Hello everyone
I came across this old discussion, I downloaded the files and I found it really useful, but I also wanted to make a request to jenuary of implementation to his add.in.
in a discussion that I opened:https://www.cad3d.it/forum1/threads...chio-modello-alla-modifica.54517/#post-424851 I asked if it was possible, at the time of saving a part or an axieme, to create a "old-version" folder in which the model was saved before making changes.
In practice I open my pippo.sldprt part, change of the parameters of the functions, save, and in the workbook I find another folder called "old.version" with inside pippo-old-1.sldprt, pippo-old-2.sldprt, etc. with previous versions of the part file I modified, to each save a different file.
this is a defoult function on inventor that I think very useful.
I was wondering if this addin could do this.
thank you very much and really congratulations to jenuary for the work done
Hello everyone
in a discussion that I opened:https://www.cad3d.it/forum1/threads...chio-modello-alla-modifica.54517/#post-424851I asked if it was possible, at the time of saving a part or an axieme, to create a "old-version" folder in which the model was saved before making changes.
it is more than feasible and is a good idea,
I'll put it in the next revision of the addin.
hi jenuary really thank you for your add-inn, I ask you if a possible implementation is feasible: having opened a set it is possible to automatically export all tables of his children even if the positions of the file are scattered around?
I'll give you an example: I have to send the laser cut (step+dwg) of the pieces I create a fictitious set with the pieces in the right quantity, I make a pack&go in a specific folder so that I have doubled flattened in one directory and then I launch your add-in.
Is that a feasible thing?
Hi brn,
the problem is the model has no position reference of the table, that is, it does not know where it is.
you know the pdm because when you give him the folders to manage, he indexes the files and keeps control.
Alternatively you could scan the disk but could result in more tables with the same name and it's not okay.
if the boards are on the same director of the part there are no problems, at the limit you could tell him about which directors to look for.
hi, I installed rel. 4.0 and it works perfectly.
thank you very much to jenuary for the precious contribution!
Thank you very much!! you saved me hours and hours of time!! and the shop wants everything in pdf...and some suppliers in dwg...and others in dxf.. and others in step...
Thank you! !
Good morning to all, I try to write here my request since the discussion could be similar.
I'll explain the problem.
I have a swx part file that contains "n" configurations.
Suppose the side file is called "parte.sldprt" while assuming that the configurations are called "conf1"; "conf2"; "conf3"; "conf4", etc...
what I would like to do is generate "n" pdf file and "n" file in dwg whose name would be:
"conf1.pdf" - "conf1.dwg"
"conf2.pdf" - "conf2.dwg"
"conf3.pdf" - "conf3.dwg"
Now, I ask you this, because first I don't know if you can do it.
the file name would be crucial, as this file would be hooked to an executable program (developed internally) of encoding that would be able to take automatically (after creation, of course) the file as long as it has this name.
Basically it is a very basic version of a configurator.
I ask you first if someone has already had similar experiences or if you can do (if with a macro or other methods).
I attach an image that can help clarify what I should do
thanks in advance
thanks in advance
the discourse of the most configurations to put on the table, you have to act force on the views of the table, or having opened the 3d model you have to load the table with the current active configuration... We have already talked about it on the forum. Try to search....I think you can't do it, regardless of macro or not.
in the other discussion I didn't ask you, but the pdf and dwg of what?
of the file leaves? in this case of a specific view or opening view?
from the drawing file? in such case does these files already exist or should it be created? if it must be created with what views? with quotas?
add more information to circumscribe the need
Staff online
