solidworks file display with layer selection
  • Thread starter Thread starter som
som
I wanted to ask you if you know a program that allows you to view slddrw files and that allows you to activate or disable the layers that make up the drawing.
I tried edrawings and solidworks viewer and I don't think these two allow to select the layers to display.
Thank you very much:
but, with edrawings the layers are visible and selectable. . at least
with swx 2010. .
thanks for the answer,
will depend on the version with which the drawings are made? My parents are from the 2005 version. do you have an example of files that with edrawings allows you to choose layers?
Very kind.
depends on the version with which the design was created... with your I see the various layers and I can select them. :finger:
Thank you very much.
